Hi,
I have been adding some farkle to my new to me 2005 GT200 and recently decided to add the Piaggio Front Turn Signal with LED Running Lights Kit #MV000475. I did not get the instructions with the kit (no thanks to Scooterpartsco for lack of support) but found it online elsewhere. Today i did the installation after making up the small wiring harness. I had a problem installing the amber parking bulbs as the receptacle does not seem to be a good match for the bayonet bulb locking pins but I got them in after some modifying. Then it came time to splice the wiring harness for the parking lights onto an available hot wire. I watched Robot's video but he had a newer 300 and everything is not quite the same. Has anyone installed this kit and what wire did you splice into? Thanks for any help you can supply.
