Picked up my first project scooter in over a decade yesterday, so I'm rusty, particularly with the moderns.
It's a 2008 S150, and the guy who had it only could confirm it had been declared a total loss by the previous owner's insurance company although there weren't outwardly any visible signs why. Now that it's in my possession and I've given it the cursory glance over, I'm guessing it was a theft recovery and sat for several years either before or after.
Obviously draining the gas and cleaning the carb are in order. Few questions though:
This model has a fuel pump, which is a first for me. I watched the Scooterwest video* of a similar S150 project, where Robot swaps out the original fuel tap for the older vacuum style. That new part he puts in has a built in fuel filter. What about for the original fuel tap, which I didn't see in the video? Should I be replacing the fuel tap proactively now as well?
There is a loose, uncapped hose coming from the rear of the scooter. Guessing that was previously connected to the rollover valve (which appears to have been cut out along with the canister). Do I need to cap this or do something else with this hose?
I have the key, put a new battery in, and checked to see if the electronics come on. The headlight, horn and starter motor all function. I did notice that no fuel was moving through the clear fuel line. Once the carb is clean, tank is drained (and possibly the fuel tap replaced) should I expect to see gas flowing through the fuel line when I'm pushing the starter button?
Few other things I'll have to replace: the boot between the crankcase and the carb is damaged (was duct taped together when I bought it), and the seat latch release was cut out. Will those parts be interchangeable with an LX150?
*https://www.youtube.com/watch?v=xbHgOOLDUvA
