Hi
Trying to get rid of a flat spot for ages. I have recently removed the engine and:
- new spark plug (Champion RG4 HC just in case)
- Checked valves clearances (only slightly out)
-blanked off the SAS Secondary Air gizmo and also blanked off the stem of a t-connector (on the vacuum line between the inlet manifold and the fuel area)
Scoot now starts beautifully, has a better tick over - nice and steady - and the scooter is now much much better on steadily applied acceleration.
But.... it still has a tendency to stall / falter on cracking open the throttle too suddenly when stationary. (Tommy Cooper would say "well, don't do it then"!!) and there is a lag of about 1/2 second when doing the same when on the move. Steady, gentle throttle action is necessary.
I have settled on 4 turns (4X180 degrees) out on the mixture brass screw on the carb because the faltering is worse either side of that - I've tried 5 and 6 turns and 2 and 3 turns (oddly its faltering /dying behaviour seems equally badly either side of 4 turns)
Is there anything else that I should be checking or adjusting?Many thanks
