I replaced all the bearings and seals in a VBC about a year ago...and its sat since then and stared once 3 month ago
Yesterday I pulled it out ..it started second kick but would not idle no matter what i did..changed the plug for new.....no symptom change..altered air fuel..still no idle
Cleaned the carb and put all new gaskets in it including under carb box and carb itself
No change
Then ...as I was cleaning around the carb box cover with CRC whilst engine running I heard the revs creep up
also weirdly if I tip the scoot on its side while running the revs increase
Engine oil all nice and thick and clean with no gas smell
soooooo smacks of fly side seal leak
Do they dry out if you dont use them regularly?(seals that is)
