'08 Vespa LX80, '07 LX50
Hey new person here, hopefully this is a good location for my question. I got my hands on a new to me 2009 LX50 and most of the chrome stuff (and chrome plated plastic) is looking pretty tired. I have been poking around the internet for some aluminum stuff to replace it. Does rust proof stuff exist? The seat handle grab rail is high on my list to replace. Thanks for any help!
@dooglas avatar
GTS 300ABS, Buddy Kick 125
@dooglas avatar
Having metal pieces rechromed is really too expensive these days, and only a few shops still do that work. On the other hand, powdercoating is an excellent finish and rust proofing. If you have several pieces you want done, the price for the lot will likely be cheaper than replacing them. And you get a choice of finishes. Gloss silver, matte silver, gloss black, matte black, etc.
Thanks for a reply Dooglas. I am in a harsh environment for metal toys so I try to look for premium materials that I don't have to think about again. I'm a bit surprised that there aren't more choices for people like me...or at least I have not found any yet. Cheers
@wheelman-111 avatar
2010 S50 Modified "Punkin"; 2003 ET4 Malossi 187 "ISO"
Greetings:
I too live close to the ocean.
Probably there's a limited aftermarket, and some of that won't even be as high-quality as the stock material. Replace, then keep clean, polished and generously waxed.
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
You can start with this one maybe?
@dooglas avatar
@dooglas avatar
I am a long time boater as well as a scooter rider, so I have struggled with "harsh environments" for many years. Aluminum also takes a beating in salt air environments. Even "stainless steel" corrodes. The trick is a durable coating applied with good surface prep such as anodizing or powder coating.
@syd avatar
@syd avatar
I'm with Dooglas. I knew a hotrodder who brought a powdercoated part to work and asked me to take a hammer to it. Strong stuff.
You guys that like powder coat aren't wrong, it's not a bad finish for what I'm after. It's just that out here there is no competition so things are stupid expensive! I'll figure out a path here I did refinish the reflectors, tail light and part of the grab bar with self etching primer, gloss black and then clear rattle can and it looks good but time will tell if that treatment holds up to the elements or not. I probably need to pop a couple pictures up...hmmmm
@fudmucker avatar
@fudmucker avatar
As in most cases, the success of the finish is dependent on surface preparation.
Removing chrome plating is difficult.
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
Right, many years ago I had the GTS rear chrome rack done. The result was less than desirable. I am embarassed even to post a picture.😏
@attila avatar
@attila avatar
Hello Hawaiian.
Happy to see you here among us people of scooters.
Welcome to MV from Latina, Italy.
PS: I also live in a city near the sea.
[ Time: 0.0116s ][ Queries: 4 (0.0022s) ][ live ][ 343 ][ ThingOne ]
