According to Robot on his SS 180 Youtube review, the top of the tank was moved up for a bit more capacity and the bottom was as well for better gravity feed or 'head'. It seems to me that if that if the top and the bottom were both moved up, the capacity would basically remain the same. The specs on the SS list a greater capacity than the standard tank.
Using my lazer level, I find that with the (wrong) VBB tank on my SS, the bottom of the tank is level with the banjo on the carb. Little 'head'. On the Motovespa, the bottom of the tank is 1 1/4" above the banjo. Better 'head'.
The motor runs beautifully but I am having fuel flow issues at a point where the gas is right about level with the top of the tap filter. Even on reserve. I disconnected the banjo from the carb and with it held below the carb the flow is good ( tap is clear) but as I raise it up level with the top of the carb it slows down significantly. Fuel line is cut down to 18".
I ordered a replacement GS/SS tank and the distance from the flange to the bottom of the tank is exactly the same. I see there are two tanks available: a GS/SS tank and a 'long distance' tank which incorporates the bubble top with the standard bottom. Is there, or was there, a tank with a raised bottom ?
Edit: actually I should have said that with the bottom level with the banjo there is no 'head'.
