Gts 300 notte
Gts 300 notte
hello, just wondering if vespa will start in cold weather? its kept in an underground garage, but if i drive to somewhere, park it for a few hours, then when i come back to it, will there be a problem starting it up? canadian winters can be pretty brutal but the coldest i would drive it around would probably 0 and above.. just wondering if there will be start up problems in cold weather. thank you!
gts super 300
@dooglas avatar
GTS 300ABS, Buddy Kick 125
@dooglas avatar
Shouldn't be at 0 C and above (32 F), assuming that your battery is charged up. Mine starts up in the 30s just fine.
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
The only problem would be hypothermia if not properly attired.
@ardenstone avatar
BV400
@ardenstone avatar
BV400
I didn't have a Vespa per say when I lived in colder climes, but kept whatever scooter I was riding outside (Kymco 250cc and later BV350) and didn't have a problem. I did use a cover over-night, and usually drove as long as it was above about 18 F / -7.5 C (most days). That was about my limit before it was too miserable and I hitched a ride, etc.
Battery tender if you're not going to be riding it for a while, though. Which I'm bad at knowing ahead of time!
@attila avatar
@attila avatar
My grandfather on his Moto Guzzi 500 in 1936, lit a small fire under the engine to de-freeze it.
Obviously there wasn't all the plastic today and the motorcycle didn't catch fire.
@harbinger avatar
@harbinger avatar
Yeah no issue at all. I ride my Vespa year round and it starts just fine in even -15C . Actually all my bikes do but of course you want a reliable battery. My bikes are also kept in an underground garage.
@bob_copeland avatar
Firing Up the Vespa in the Cold
The real advantage is fuel injection. The Vespa fires right off if your
battery is good. I start mine in the garage wen it is 10 below zero F.
I am done for the season. The scoot is off on a long Winters Nap.
Bob Copeland
I'm with Bob. Black Beauty is getting winterized this weekend. I'm intrigued by people in the North riding through Winter. Our roads in Michigan are treacherous for SUV's, let alone a scooter. Rey jealous...
BV 350, Suzuki VanVan, Triumph Street Twin
Yep, Bob nailed it. Since having fuel injected bikes year round riding has literally been the push of a button!
JEB
2023 Vespa GTS 300
2023 Vespa GTS 300
Number one reason people get stuck somewhere with their motorcycle or scooter is a dead or low battery. If you do serious commuting and/or need to have a scooter start every day, all year round, replace the battery as soon as the warranty runs out (usually once a year). It's part of your commuting expense, IMO.
Toss the Battery & Fuel Injection
Joehouston,
I am with you. I want a fresh reliable battery. I go so long and just
toss them for new. As a result, I have never been stranded.
Jebarrett,
The wonder of fuel injection in the scooter world. My first scoot was a
Piaggo Scarabeo 150 without fuel injection. The scoot, without fuel injection,
would rumble grumble turning over to start. Even after it was started, while the motor was still cold, it would stall when I stopped. After it warmed up, it
was fine and a great scoot to ride.
In the Spring, after sleeping all Winter, it would take forever to get it to
fire off and start. I know the fuel, even with stabilizer, can get stale. Despite this, it was a cold beast to start. Thank the world for fuel injection.
Bob Copeland
Frost Bite Falls Minnesota
Great Ride - but, a cold beast. Scarabeo 150
@amateriat avatar
@amateriat avatar
The Fire Down Below
The only thing standing between your Vespa starting and not starting on silly-cold mornings is That Battery. Keep it strong (via regular use and/or a battery tender...strongly advise having a charging cable installed on the bike for fuss-free access), and, all else being in order, the bike will crank, no problem.
The Night of the Lowside: Still started up.
@rallygeek avatar
@rallygeek avatar
Wow, riding on snow sounds scary. Agree with the battery tender solution. Here in London January is getting a little too cold, I always ride until the point when my heavy gloves can't stop my fingers going numb. That always seems a sensible time to stop.
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
winter riding
I been on my Vespa in temperatures as low as 20° F (about -7 Celsius). I enjoy riding PTWs in winter and so far no issues with starting and running the Vespa engine when it's frigid outside.
But as others have said: you do want to be sure your battery is in good condition, as that kind of weather isn't a great time for surprises.
@attila avatar
@attila avatar
Re: The Fire Down Below
But don't you slip while driving on the snow? And...yes, the battery is the problem, especially if it is a few years old.
However they also sell small electronic starters.
@kimpossible avatar
Tethys - 2012 GTS 300
@kimpossible avatar
7 degrees F
I do always keep mine on a battery tender, but the office parking lot is a wide-open windswept plain. After 10 hours at 7 F it started right up!
Kim
[ Time: 0.0121s ][ Queries: 4 (0.0032s) ][ live ][ 343 ][ ThingOne ]
