@mjrally avatar
@mjrally avatar
I tore apart my P200 looking at one problem and found 4 others One of them being both piston rings were glued in to their slots with lots of blow by. The top end has 2 years of use on it and while the crown looks fair, the ring grooves are all gunked up.
Anyone got any recommendations for an overnight soak to help clean out the grooves? The dental pick/screwdrivers aren't doing the best job by themselves.
@markosmarkos avatar
I had a piston with stuck rings. An old broken ring, a file to make sure the broken edges were clean and sharp, some simple green, and some elbow-grease and the grooves cleaned up really nice.
Hope this helps.
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Does this happen because of the type of two stroke oil being used? Is there a better synthetic oil that could reduce the issue?
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
Simple green mixed with near boiling water and let it soak a bit.
2007 Stella 225
2007 Stella 225
How about using an ultrasound cleaner?
@waspmike avatar
@waspmike avatar
Mr. Muscle oven cleaner.
Although can says not on aluminum it doesn't actually harm aluminum. Might take the shine of aluminum plate but does no serious harm.
If overly concerned you can test yourself on an old bit of aluminum.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Another vote for oven cleaner. It's sodium hydroxide... a relatively mild acid. My brand is "Rinso" ... lemon scented.
@greasy125 avatar
@greasy125 avatar
dollar store oven cleaner for the quickness.
pine-sol for an overnight.
carb dip/carb cleaner or brake clean for an in between the two, especially good with a wire brush and part of an old broken ring to scrape.
hth!
-g
@vespergeezer avatar
GTS300, Cosa LX200
GTS300, Cosa LX200
Nerd emoticon Sodium hydroxide is an alkali, not an acid, (weak or otherwise)...
@moto64 avatar
@moto64 avatar
Just be sure you don't scrape up the bottom 'land' of the ring groove as that is the seal for the ring.
@waspmike avatar
@waspmike avatar
Use soft plastic/wood scrapers or tooth picks
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
It's lye. It works. Don't be frightened of it.
GTS300, Cosa LX200
GTS300, Cosa LX200
No word of a lie! Laughing emoticon (But use sensible precautions).
BTW 'lye' refers to a group of metal hydroxides- usually potassium or sodium hydroxide...
Every day is a school day.
[ Time: 0.0118s ][ Queries: 4 (0.0029s) ][ live ][ 343 ][ ThingOne ]
