So... electrical issues; my 74 Rally has a few. Mainly nothing electrical works on the bike. No head light, no tail light; nada. The 6v battery shows a charge but when I start the bike and take a volt reading at the battery is shows 0. Is that normal?
that would be a dead battery (but could also be a short somewhere), so that would be the first place to start.
on the '74 everything but the ignition runs off the battery, so you can test it without starting the engine. (and the engine can run without a battery) the + side of the battery goes to the key and then back to the fuse block. so if you unplug the outbound side of the fuse block, you can test that the power is making it that far ok. make sure you keep fuses in the loop while testing, don't want to melt any wires. here's a partial diagram of the battery and rectifier connections from when I converted to 12v, but I kept the stock layout of the wires, so that may help. https://modernvespa.com/forum/post2153859#2153859 |
If the battery was showing 5-6 volts before I started the scooter how is that a dead battery? I have been kind of troubleshooting some things; could it be possible that a wire on stator could be disconnected or something?
'65 Sprint 177/ '17 GTS300
Posts: 470 Location: Dorset, UK |
So when you stop the scoot the volts mysteriously come right back??
A knackered battery also wont be able to handle any load. So when a load is put upon it the volts go right down as its trying to throw current to the load and it fails causing a brown out (ie volts go down) Try a new battery...or bung on a suitably rated DC Power supply (if you can get your hands on one) |
often a battery that is "dead" will still show a charge when there is no load, but as soon as even the lowest of loads is applied the voltage will drop.
If you connect a light bulb across it, does it light up, or does the voltage drop? |
1972 Vespa GTR, 1963 Lambretta LI 125, Royal Alloy GP125
Posts: 226 Location: Halifax, England |
You should always try to test a battery under load to see if it is flat or knackered as mentioned above. As well as that a healthy 6V battery should read nearer 7 when tested not under load.
So I changed the battery and the lights work. Dim but they were on. The next day I went for a cruise and they lights don't work again. My battery is dead again. The lights only work while it is running so how can I turn them off so my battery won't drain. Thanks so much for the help.
Posts: 5363 Location: Oceanside, CA |
74 Rally 6V charging systems have a reputation as being a red headed stepchild. Everything has to be perfect in order for them to work.
One option that a lot of frustrated folks do is to plug the battery into a battery tender after each ride. That way you dont ruin the battery discharging it repeatedly. https://www.amazon.com/6-volt-battery-tender/s?k=6+volt+battery+tender Second option is to remove the battery entirely and just run off the stator. The downside to that is you'll lose the horn and turn signals and your lights will dim according to engine rpms. |
2007 Stella 225
Posts: 3547 Location: Rochester, Minnesota |
1Rally1Tully wrote: So I changed the battery and the lights work. Dim but they were on. The next day I went for a cruise and they lights don't work again. My battery is dead again. The lights only work while it is running so how can I turn them off so my battery won't drain. Thanks so much for the help. 1) You originally had a battery that was dead or drained. 2) The scooter would run but with no headlight etc. 3) You put in a new battery with a charge, then everything worked again. 4) After sitting all night the battery is dead again? If that is correct, I would charge the battery again ASAP, an SLI ( starter lights and ignition) battery isn't made to be discharged and your going to ruin another battery. Once charged, attach a multimeter to the battery leads. With scooter running, is the voltage increasing or decreasing? If its decreasing your charging system isn't working. Does the headlight output fluctuate with the RPM? It should get brighter and the voltage on your meter should stay the same or increase. If it's charging while revving up and riding, but goes dead sitting and off something is draining the battery. With the scooter off, disconnect the positive lead, set your meter to measure current and place the leads in series between the positive post and battery wire. The current draw should be "0" if not start disconnecting stuff with the meter hooked up until the current draw goes to zero. Then fix whatever you disconnected last. As far as turning off the headlight, its a safety feature in the US to not be able to be turned off. Required by law to be on, not sure where your located. |
