Old douglas ..smallie with polini 115..super with nasco 177
what difference in % would I get from matching the cases vs not. I expect the displacement increase to be felt...will matching it to the cases really make a no ticeable difference...and if you were going to put a number on it how much more top end or acceleration am i missing out on??
to split or not?......not after a screamer.....just want it to run so a newbie 16 year old can learn to ride....the original 50cc had poor compression and I already had the dr85.
Not planning on gearing change...or should I....which would add another vote l to splitting
soooo bolt on the dr 85 and go..or split match and gear change?
what say ye
I have a DR70 on a PK50 and the gearing seems OK. You could consider taller primary gears if it winds out too easy in fourth. If you want to consider a little cheating, look over here to case match etc with no splitting. Cannot recommend...
play dough works well also
@markosmarkos avatar
Someone brought this up before about wasted efforts.... how port matching may not yield what we envision or imagine....
I am just reposting the vid. I have no data to base this on, but it seems that if we are not trying to build a 44hp 13,750rpm 125cc monster, just bolt it on and go... for now. Quick and easy. Or you could go the route of Voodoo without splitting the cases.
If there is a need for 'more' down the line, then split the cases. Just my 2 cents.
Hope this helps.
wasted tuning?
https://www.youtube.com/watch?v=SxQV0xz4q6E
highest revving 2 strokes
https://www.youtube.com/watch?v=4fr4R2bFuoA
wasted tuning:
highest revving:
monster!
monster!
Completely agree, although I wanted it for bigger carb and decent pipe as well.
OP, are you running a 19 carb? If not, you'll want one, maybe a good pipe as well.
What are the thoughts on a Polini 85? I've got one cheap and was going to have a play with the exhaust port size and shape.
Does anyone have a measurement from the top of the barrel to the exhaust for a 180ish duration? Ive got a zirri exhaust that i bought a while ago but haven't done any barrel tuning yet to get it to work.
[ Time: 0.0130s ][ Queries: 4 (0.0057s) ][ live ][ 343 ][ ThingOne ]
