Today I took my 2016 Sprint out for a spin on a lovely Delmarva afternoon. Decided that I had better stop for gas about 8 miles from home. Filled up and went to start up and dead! Figured it might be the battery but also wanted to check the fuses. Pulled each of the fuses in the glove compartment and when I pulled the bottom 5 amp it dropped into the hole where the box is hinged and landed under the floor board. I had called my lovely wife to bring me my portable battery jumper and when she got there we tried to jump it but still not even a click. With a missing fuse I knew I had to replace it before I would know if it was the battery or some other electrical issue. Luckily we were near a NAPA store so I got a new fuse, hooked up the booster and alleluia it started! Got home and ordered a Yuasa battery. Moral of the story is that before pulling those glove box fuses, stuff the hinge opening with a bit of cloth or tape lest the fuse finds its way to the bottom of the scoot!
Thanks for the tip fergy. There's a few black holes on these Vespas where fixings disappear. The obvious one on the GTS is when removing the screw that holds the headlight cover in place. Even with a rag placed across the void behind the horn cover I have managed to lose a screw.
