Yes it is easy but I wanted to share some details that aren't clear when you find other posts on installing any accessories using the Round Alarm Connector for switched power.
The alarm connector module on 2015 and onwards GTS 300 isn't actually reachable from the left knee pad opening. It is located behind the horn cover towards the right side when you are facing the vehicle. It is attached to a post with a zip tie and getting to it is not easy when you open the horn cover
The white wire remains the switched power source. Splicing into the power source isn't easy and will require a way to pull up the alarm connector closer to the opening without ripping any wires, takes a bit of time but can be accomplished.
I am attaching some pictures so others may benefit from it if they undertake either installing heated grips or any other accessories that would use the alarm connector.
What makes sense is if you plan on adding accessories that use switched power, once you attach the positap connector , run a wire back to the knee pad and connect accessories from there and possible run a ground wire as well.
I don't plan on adding anymore devices though a nice USB 2 port unit outside on the knee pad maybe worth it. Currently there is one inside the glove compartment and I am not sure how the lid closes when a USB wire is run out from glove compartment.
