Is it ok to put SW5-30 motor oil in my 2020 Vespa 300 gts hpe? Or do I need to return it and get SW5-40 motor oil?
Posts: 7714 Location: Madison, Wisconsin |
Re: Motor oil
MarshWasp wrote: Is it ok to put SW5-30 motor oil in my 2020 Vespa 300 gts hpe? Or do I need to return it and get SW5-40 motor oil? To answer your questions: Probably not, and yes but we need to get more specific. RTFM. |
Posts: 2137 Location: Pretoria, South Africa |
Re: Motor oil
MarshWasp wrote: Is it ok to put SW5-30 motor oil in my 2020 Vespa 300 gts hpe? Or do I need to return it and get SW5-40 motor oil? Where I live in the sunny South of Africa, we very seldom get temperatures in the single digits, so I could probably get good service from 10W-40. I use 5w-40 in my Vespa 300 GTS because it is the same grade of oil specified for my BMW 1200 motorcycles and my Subaru Forester, so I can buy it in more economical 5 litre packs and use it for all of them, both top-up and oil change. |
I'm thinking the "S" in SW refers to it being synthetic.
Vespa recommends 5W-40 as it does not thin out as readily as 5W-30 oil. I never use anything other than 5W-40. Vespa motors are high rpm and hot running. You need a really good oil. |
Posts: 4175 Location: Kingdom of Lanna |
Re: Motor oil
MarshWasp wrote: Is it ok to put SW5-30 motor oil in my 2020 Vespa 300 gts hpe? Or do I need to return it and get SW5-40 motor oil? |
2020 GTS 300 HPE ('19 - '26)
Posts: 1476 Location: NYC |
It's easy to buy the right oil. If you live near a Cycle Gear, you can even pick it up in store!
Vespa GTS 150 3v SUPER. Vespa V100 x 1. Lambretta Li150 x 1. Px 125 x 2. Px 200 x 1 (red bull special) T5 Classic x 1. Vespa Cosa x 2.CF moto 650mt
Posts: 392 Location: Perth Australia |
RIP
Posts: 8291 Location: Latina (Italy) |
Posts: 3766 Location: East Anglia, UK |
Re: Motor oil
MarshWasp wrote: Is it ok to put SW5-30 motor oil in my 2020 Vespa 300 gts hpe? Or do I need to return it and get SW5-40 motor oil? Yes, unless you are in a very cold environment I'd go with the genuine 5w-40 fully synthetic motorcycle oil. It will protect your engine much better. Take a look at this. https://www.total.co.uk/difference-between-5w30-5w40-engine-oil It's the same irrespective of whether you are talking about car or mc oil. Good luck. |
MarshWasp wrote: Thank you for your help, good information to know |
From what I can see very very few oil threads actually go bad! Even the ones that go bad are hardly bad at all.
Yes they are! No they're not! Lol.... |
Posts: 12026 Location: Hermit Kingdom |
Max6200 wrote: MarshWasp wrote: Thank you for your help, good information to know |
znomit wrote: Max6200 wrote: MarshWasp wrote: Thank you for your help, good information to know |
Posts: 1952 Location: Hamilton/Kirikiriroa, NZ |
Max6200 wrote: znomit wrote: Max6200 wrote: MarshWasp wrote: Thank you for your help, good information to know |
