⚠️ Last edited by Abner_Bjorn on UTC; edited 1 time
Posts: 1680 Location: Denver |
Good morning MV. Can I start up a BV350 with the variator removed? I have a 2013 That has something strange going on. I think it is in the clutch. The scooter has 13,000 miles. It won't start. It makes a brief horrible grinding squeel from the rear of the CVT when I push on the starter button. I'd like to remove the variator and belt, and see if it starts disengaged from the clutch. Any input on the clutch issue would also be appreciated. Thank you!
Red Devil SH150i (11,000)
Posts: 3341 Location: Orange Park Florida |
Abner_Bjorn wrote: Scooter is a 2013 with 13,500 miles. Was running fine, and I let it set for 2 days. Started it up, and took off. A block away the oil pressure warning light came on. Scooter started to bog down a bit. I rode it back home. Ordered and installed the new boot and plug. Battery is fully charged showing 12.4, 11 when cranking. and 14.3 running. I started it up, no oil pressure light. Rode it 2 blocks, oil pressure light came on. Scooter came to a crawl like it was in "limp mode", and died. I rolled it home. If it does turn, you need to remove the oil pressure sender and install pressure gauge to see why your oil light is on. |
GTS300 Super 2023 Beige
Posts: 3513 Location: Sydney, Australia |
I did this once with my GTS250, and the result was a bent valve stem. When the variator isn't locked in place on the crankshaft, the sprocket for the timing chain can come loose, and valve timing is messed up.
I expect the BV has the same arrangement there, so I wouldn't try it. |
Posts: 7714 Location: Madison, Wisconsin |
If you have taken it apart far enough to remove the clutch, was there something suspicious about it? Personally I am not about to suggest you try to start it with the variator out.
I did a belt and rollers. Put about 20 miles on it. Scooter was working fine. I let it sit for 2 days. I got a block away from my house and the oil warning light came on. I turned around and went back home. I charged the battery, replaced the cap and plug. It started right up, no oil light. I made it down the block and the oil light came back on, and it died, so I coasted down hill back to my house. Now when I go to start it, it makes the binding, grinding clutch noise and will not fire. Also before I did the belt, I noticed the rear wheel was spinning fairly fast at idle if that helps diagnose at all.
Abner_Bjorn wrote: I did a belt and rollers. Put about 20 miles on it. Scooter was working fine. I let it sit for 2 days. I got a block away from my house and the oil warning light came on. I turned around and went back home. I charged the battery, replaced the cap and plug. It started right up, no oil light. I made it down the block and the oil light came back on, and it died, so I coasted down hill back to my house. Now when I go to start it, it makes the binding, grinding clutch noise and will not fire. Also before I did the belt, I noticed the rear wheel was spinning fairly fast at idle if that helps diagnose at all. To answer your original question - No, I would not advise running the engine with the variator removed. There is a possibility causing the timing chain to jump. Also, there is a chain on the other side of the crank (flywheel side) that drives the oil pump and the chain or associated parts could be damaged as well. So if you did run it with the variator removed when you last worked on it perhaps you could have damaged the oil pump drive. |
Posts: 46412 Location: Pleasant Hill, CA |
You can run the engine without the belt, but NOT without the variator.
I suspect you have some trouble inside the clutch. I understand there's been quite a demand on replacements - why I don't know. |
Ok. I think I'm hosed. I did as Breakinwind suggested. Motor turned fine, but with a hell of a squeal. Didn't know where that was coming from, so I pulled the aluminum CVT cover, clutch and variator. My squeal is internal to the engine. Any idea how bad off I am? Thank you in advance.
"https://www.youtube.com/watch?v=j5F3rd39w6Q&feature=youtu.be"
Abner_Bjorn wrote: Ok. I think I'm hosed. I did as Breakinwind suggested. Motor turned fine, but with a hell of a squeal. Didn't know where that was coming from, so I pulled the aluminum CVT cover, clutch and variator. My squeal is internal to the engine. Any idea how bad off I am? Thank you in advance. "https://www.youtube.com/watch?v=j5F3rd39w6Q&feature=youtu.be" |
Posts: 719 Location: Winston-Salem, NC |
I did exactly what you did. When I put the variator on I didn't get it on all of the way. Probably was in a hurry and didn't confirm the belt was out of the way and tightened on it. I was lucky and didn't go far before the timing chain jumped its sprocket and the oil pump stopped working. It was still a big job to get it back together and running right. It sounds like you may not be so lucky. You need to pull the valve cover and see what's going on in there.
Please see my previous post. Sorry, I know it sucks. Pull the valve cover and the flywheel cover. You'll likely find your answer.
