@miguel avatar
@miguel avatar
I suffer from a mild case of tinnitus - ringing in the ear - as do about 1/3 of the population(!!). For me it's a high pitched tone in both ears. Others experience different sounds like garbled noise, whistling, clicking. Tinnitus is a neurological disease and is often a 24x7, life-long ailment for which there is no cure. In some cases it just goes away, if you are lucky. It's a terrible disease. It is often caused by exposure to loud noise such as wind and engine noise (think open-pipe Harley) in motorcycle helmets.
In my case, loud noises exacerbate my tinnitus. Hence, I'm always looking for ways to reduce the noise level in my helmet.
A couple years ago, I purchased wired Libratone noise-canceling earbud headphones. They worked extremely well and I wrote about their helmet noise-reduction performance here in addition to other measures I've taken to mitigate helmet noise.
I wanted to try Apple's AirPods Pro to see if they performed better than the Libratone thinking that perhaps the noise cancellation had gotten better. There's no easy way to objectively measure their relative performance so I can only provide subjective performance.
Honestly, they both did well and there were relatively insignificant difference. So for me the choice comes down other features.
Libratone pros and cons...
o Powered from the phone so no charging or charger case required
o Single unit and tethered to the phone via the cord so not easy to lose
o Controllable via buttons on the cord so controls are accessible while wearing helmet
o Four levels of cancellation from none to strong cancellation
o Good sound quality if you want to listen to music
o Simple to use and the controls on the cord don't require you to take your eyes off the road. I can control the buttons even with leather gloves on
o Suitable for all-day riding since they are powered from the phone and don't reduce the battery life significantly
o I could not come up with any negatives
o ~$80
AirPods Pro pros and cons...
o Powered from internal battery so charging or charger case required
o Three pieces: left and right earbud and charging case and relatively easy to lose IMO
o Controllable via buttons on the earbuds so not directly accessible while wearing helmet. You can control them via the iPhone's Bluetooth app as well but you have to have the phone accessible
o Two levels of cancellation: none to strong
o Simple to use if you have the phone mounted on your handlebars but you have to take your eyes off the road and focus on the phone
o Not suitable for all day riding because the batteries last 3-4 hours
o ~$200
I bicycled to the market last night with the AirPods in my ears. When I removed my helmet, they popped out of my ears and onto the ground. I'd forgotten I had them in my ears - they are that comfortable. But it confirmed just how easy they are to lose.
My recommendation: I liked the Libratone's better for in-helmet noise cancellation because their features suited me better and its unlikely I'll lose them. While I like many features of the AirPod Pros, I just know I'd lose one of the earbuds. So I'm returning the AirPods and sticking with the Libratones.
The Libratone and AirPods work flawlessly with my iPhone. I have no idea how they might work with Android or Windows phones.
Finally, my bikes have always had full-sized windscreens which tremendously reduces helmet noise. If I stand up and expose my helmet to the wind at speed, neither earbuds effectively reduced the wind noise.
Noise in motorcycle helmets is dependent on several factors: the windscreen design, helmet design and how your head fits in it, visor up or down, and your speed. Its not easy to predict. See my Libratone thread above on the measures I took to reduce noise inside your motorcycle helmet.
Take care to protect your hearing. Long exposure to loud noise, such as
wind and motor noise inside your motorcycle helmet can and will cause permanent hearing damage over time and you are likely to develop tinnitus. Trust me, you do not want to get tinnitus.
Hope that was helpful.
Miguel
@attila avatar
@attila avatar
I also have tinnitus ... it's ten years I suffer from it.
[ Time: 0.0086s ][ Queries: 3 (0.0026s) ][ live ][ 343 ][ ThingOne ]
