Old douglas ..smallie with polini 115..super with nasco 177
I need to make a new one as the old is all beat up and cracked....a normal washer filed down will fit but is too hard to bend over....so what do I make it out of that will be both maleable and not get metal fatigue..considered modifying an old primary drive/xmas tree lock washer by cutting off two tabs
Ideas?
@oopsclunkthud avatar
1:3
are they not available?
Thickness matters as it would change the position of the cross. Tab washers are dead soft to start and work harden when you bend them. so cut one from shim stock, head red and let cool slowly.
[ Time: 0.0111s ][ Queries: 3 (0.0024s) ][ live ][ 343 ][ ThingOne ]
