@mjrally avatar
@mjrally avatar
Someone sold me a brand new Malossi aluminum cylinder and piston for $75. Sadly theres no head, no rings and no details.
A quick look on Malossistore and SIP for any details has come up with even more questions.
I found on scooterwest they sell 68.5mm rings but would like to complete the set.
So question 1. Im thinking its the discontinued Aluminum 210 kit. Anyone know how I can tell if its the 210 or 225? I'll have to go measure the cylinder height.
2. Were the aluminum Malossi kits stocked with heads or were you supposed to use your stock 200 Piaggio one? Or buy your own?
3. Depending on what cc/stroke length it is, anyone got any recommendations for a matching head? I'd love to find an offset spark plug head so I can use the original cylinder cover.
⚠️ Last edited by MJRally on UTC; edited 1 time
@safis avatar
@safis avatar
That was a steal!! It's the "old" Malossi 210. They came / come with & without a head. You can machine a stock one, buy the Malossi one or an MMW (touring, etc.). Rings are the same for all the 210/221 kits...
MMW head (it's the one I usually go for)...
https://www.sip-scootershop.com/en/product/cylinder-head-mmw-px200-malossi-210cm-old-sport-mhr_13013950?q=Malossi%20210%20head
Rings...
https://www.sip-scootershop.com/en/product/piston-rings-malossi-210-sport-mhr_12120000?q=Mmw%20malossi%20210
@mjrally avatar
@mjrally avatar
Safis,
Thanks for the reply! I'm assuming that kit is supposed to work with the stock 57Mm crank?
@swiss1939 avatar
@swiss1939 avatar
Its in the old instruction manual that came with my discontinued cast iron 166 kit. Attached below.
@swiss1939 avatar
@swiss1939 avatar
It was also in the previous year malossi catalog with more info, but unfortunately it seems they replaced it with new one on their website, and I deleted the copy I downloaded last year. Can't find it online anymore.
@mcweber12 avatar
1980 P200, 1974 90/100 smallframe, 1972 primavera (under construction), 1974 kawasaki F7
@mcweber12 avatar
Quite a mystery. Be interested in seeing how this one works out.
Any ideas from the guys at SW?
I also bought a NOS Malossi 210 recently, but the price was not quite as low as yours. It is strongly advised to use a 60mm crank in order to overcome the transfer duration shortcomings of this kit with a 57mm crank. Of course the cylinder can be ported along the lines of the Worb5, but the longstroke is an easier way to proceed.
I'll probably widen and reshape my exhaust port on Jack's recommendation, in order to pair it with an expansion chamber. Otherwise, I'll just experiment with 0.8, 1.0 and 1.5mm base packers to position the transfers where they need to be. Also in line with what Worb5 does, I'll work on the piston windows with a Dremel, which I've already done on my MHR 221 motor
@hibbert avatar
Vespa
@hibbert avatar
Vespa
On my Malossi CVII with 60mm crank and 1.5mm base gasket port timing is 185/126/29.7 with 0.3 PBT 1.2 squish with modified piaggio head. Details are here carbs and fuel pumps
Am eyeballing the MMW head now thank SaFis
@ginch avatar
@ginch avatar
Nice score! Here's the 2003 info on that and other Malossi kits from then.
@mjrally avatar
@mjrally avatar
Thanks Gents. Gotta wait for payday and i'll buy that head and rings.
[ Time: 0.0127s ][ Queries: 4 (0.0040s) ][ live ][ 343 ][ ThingOne ]
