Vespa ET2
Vespa ET2
Hi Everyone, Eric here in Brisbane Australia. Just picked up a 2001 Vespa ET2, my first scooter, and loving it. Despite it's age it only has 3200 miles on the clock and is in pristine condition.
I have noticed that when i enter a driveway, or go over any other sharp bump, it feels like the tire pressure is low and the rim is hitting the concrete. Of course I've checked the pressure and it is good. Would it be the suspension bottoming out? Is it time to replace the suspension, or is this normal for these scooters? Unfortunately I cant get access to a newer model to compare the ride quality.
Appreciate any advice and look forward to learning heaps more from this forum,
@dooglas avatar
GTS 300ABS, Buddy Kick 125
@dooglas avatar
I've never owned an ET2, but I suppose that it has an adjustable rear suspension like most Vespas. If so, I suggest you adjust to a higher level of preloading and see what that does.
Vespa ET2
Vespa ET2
Thanks Dooglas, I should have been more clear, I think the front is the issue, not the rear. Would the same apply?
It's twenty years old, and shocks are something that wear out.
@dooglas avatar
@dooglas avatar
No.
[ Time: 0.0097s ][ Queries: 3 (0.0032s) ][ live ][ 343 ][ ThingOne ]
