@markosmarkos avatar
So.....
70mm bore;
Alloy block with steel stock sleeve pressed in I am guessing;
Volume of 219.36cc with 57mm stroke.
Is this a good candidate for dremel and experiment?
Or just a waste of time and money??
@safis avatar
@safis avatar
No, it's crap. They seize easily. You'll get better results boring a stock cylinder with a GS or Malossi piston...
Jet Eye Master
Jet Eye Master
Exhaust stub thread stripped on one I saw. Quite an expensive cylinder, as it won't last one week.
Iron Polini 207. Highly tunable. Strong. Cheap.
Thanks for the reality check and all the good info.
Will steer clear of this one.
Thanks and Cheers.
[ Time: 0.0151s ][ Queries: 4 (0.0069s) ][ live ][ 343 ][ ThingOne ]
