I'd seen that. The socket as a spacer is a good idea except that on the starters for the smaller scooters (200cc and smaller, it seems), the armature bearing fits into a blind hole. Even if you manage to fit a socket in it, you can't push it out with the armature!
The other problem is finding "jeweler's wire" that is remotely stiff enough to hold back those springs. Maybe some kind of lockpicking or strapping steel strips could be repurposed...but I don't have those handy.
With an extra set of hands, I did manage to reseat the armature once, by wedging segments of toothpicks horizontally between the copper mesh wire and a small raised plastic nub next to each brush, and maintaining pressure while the commutator was slid into place. I was feeling pretty smug about this until the magnets in the armature casing sucked it back out as I tried to reassemble it. On inspection of the re-disassembled part, many of the brushes had gotten chipped in the process, so I decided to order a complete new starter.
Which is a shame, because there was nothing wrong with it. The brushes were barely worn after 11 years and about 5000 miles, and I didn't mind cleaning and inspecting it even if it wasn't the source of the problem.
The original problem turned out to be maybe a gummed-up, recalcitrant Bendix, but definitely stripped spline teeth in the outer variator gear. So I'm replacing the starter, Bendix, and both sides of the variator (and, galb naggit, the clutch as long as I'm taking this stuff apart). Not sure if or how one failure led to the other. But the situation went from completely normal in my driveway to making a weird grinding sound and absolutely not starting in the Home Depot parking lot.
⚠️ Last edited by Juan_ORhea on UTC; edited 1 time
