Vespa GT125
Vespa GT125
I have a question regarding cylinder head on Vespa GT125 2004.
My Vespa suffered a really bad leak of coolant into oil and vice versa and on opening the cylinder head I found the sealing plug at the bottom loose and really battered.
Fellow Vespa riders, is this repairable or should I get a replacement cylinder head straight away?
Thanks for you help in advance.
@mjrally avatar
@mjrally avatar
I would replace it and start fresh. Does your local parts supplier have any Black Friday shopping deals?
Get a Malossi 190 kit - yes I know that's not allowed if you're still on a CBT or A1 licence, but who would know...
Welcome Mar, Sorry to hear of your issue. I'm just up the road from you. We should meet up some time. Speak with your Vespa dealer. They normally offer good advice and maybe able to help without a head replacement. Although replacing the head might be the best solution. They may even have s second hand head on the shelf rescued from an engine change out. We used to keep good useable parts for just this occasion.
Jimc, if you are caught, there's now a life sentence given to folks who fit a Malossi kit and don't declare it! You also have to wear a ball and chain around your leg...lol Wha? emoticon
et4 125
et4 125
is it just a core plug ?
looks like it is
if it is
does the main dealer not sell replacement plug ?
cars have them & they push them out if the engine coolant freezes , saves the block cracking , so guessing overheating could do the same , would explain the coolant in the oil
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
looks like it is
if it is
It looks like it has been bouncing around a bit. In that case, if the seat has been damaged or nicked, a new plug may not seat and seal properly.
et4 125
et4 125
true Nightwing
like you say depends on the level of damage to be honest.
maybe with a light smear of weldseal if your lucky & it's not to badly damaged
good luck Mar
Vespa GT125
Vespa GT125
Just wanted to post an update on this problem.
I managed to buy one of those dome shaped plugs which you push in the hole and hammer in the centre to deform and create metal to metal seal.
That hole is 20mm if someone needs the dimension. There is a step at the bottom to prevent it from falling into cylinder head when pushing it in.
Put it together and it worked. Scooter back on the road.
Thanks all for suggestions.
Happy Vesping.
PS. plugs obtained from https://www.ebay.co.uk/str/njwilliamsclassics
⚠️ Last edited by Mar on UTC; edited 1 time
@berto avatar
2018 Liberty 150
@berto avatar
2018 Liberty 150
Well done! Clap emoticon
Kudos for coming back and posting about the fix. And the diagram you included is helpful too!
It would be helpful if you'd mention where you were able to source the 20mm dome plug? Is it Aluminum?
[ Time: 0.0117s ][ Queries: 4 (0.0051s) ][ live ][ 343 ][ ThingOne ]
