The glovebox on my GTS began to get tricky to open. Having read about broken hinges on MV a few times I wanted to prevent such an occurrence! It turned out that just one of the hinge plates had a loose screw - but only by one turn! That was enough to make it hard to open, much more and the plastic hinge bits might have broken, causing far more aggro.
So I'm putting this out there as a reminder - that if your glovebox gets tricky to open, remove it and tighten those screws before it becomes impossible to open without breaking it!
