@abner_bjorn avatar
@abner_bjorn avatar
Good evening fellow Vespa fans. If you are running Dr. Pulley sliders with stock belt and variator, will you please respond and let me know how it is going? I've spent the last 2 hours searching the forum looking for clear direction, and came up short. I have a 2015 GTS350. It needs belt and rollers. I want to install 13 gram Dr. Pulley sliders with a stock belt. If you have experience with this, please chime in. Do I need an extra washer to avoid oil pan problems? If I use the stock variator, a stock belt, Dr. Pulley Sliders and re-install everything the exact way it came off, will i be okay. Thank you in advance. AB
@gotmojo avatar
GTS 300, BV250
@gotmojo avatar
GTS 300, BV250
13g sliders should work well. That's what I'm running on my 2018 and I'm happy with them.
You will also need 2 new nuts, 3 guides and an OEM belt (mind the arrows). I highly recommend you first shave down the oil pan gasket with a razor blade. It should be all that is necessary to keep the belt from pulling on the fibers. If you feel a lot of rubbing on the case you can think about increasing the flat washer thickness. It won't take much if it's needed.
Torque values are important! Watch Robot's videos if you've never done it before.
After the belt ripped out two oil sump gaskets (trimmed right down!) I had to add an additional 1mm washer. That was three years ago - no problems since.
This was with 13g Dr.Pulleys, and new OEM variator and belt.
@abner_bjorn avatar
@abner_bjorn avatar
Thanks for the replies folks. Do you happen to have a link for the 1mm washer? Is this a fuzzy washer?
It's usually called a variator shim, but here on MV we call it a Fuzzy washer, after the member Fuzzy who first mentioned it.
It's part number 434885 for 1mm thick.
[ Time: 0.0118s ][ Queries: 3 (0.0045s) ][ live ][ 343 ][ ThingOne ]
