Does anyone have a tip on the removal of this rear axle bearing?
I put it in the oven @ 400 for 45min, the bearing next to it holding the 3-speed gear fell out, but this one wouldn't budge.
I don't have a special tool..
'79 - V90 / 2005 - ET2 / Stella 2t / 79 p125x
Posts: 200 Location: NJ Shore |
I put it in the oven @ 400 for 45min, the bearing next to it holding the 3-speed gear fell out, but this one wouldn't budge. I don't have a special tool..
Vespa T5 251, Lambretta GP200
Posts: 74 Location: Leeds, England |
Fill the cavity with grease and use a rubber mallet to bash the layshaft in. It might hydraulically force it out but I'm doubtful with that cage. After failing that way use a dremmel with cutting disk to relieve the tension. Do not cut through the bearing into the case, you just want to make it all weak. Take your time. Good luck.
RunsLikeSlug wrote: Fill the cavity with grease and use a rubber mallet to bash the layshaft in. It might hydraulically force it out but I'm doubtful with that cage. https://www.youtube.com/watch?v=SXxsranKaiE So maybe you'd get lucky! |
Posts: 5363 Location: Oceanside, CA |
Posts: 15123 Location: The state of insanity, SoCal |
weld a nut to it. just a few little tacks is all you need. then run a bolt thru the nut and it'll press against the case pushing the bearing out. the residual heat from the weld helps loosen everybody up.
good luck! -g |
greasy125 wrote: weld a nut to it. just a few little tacks is all you need. then run a bolt thru the nut and it'll press against the case pushing the bearing out. the residual heat from the weld helps loosen everybody up. good luck! -g drop a flat washer in the bottom before you weld a nut in it. That way the bolt is less likely to gouge the aluminum. |
whodatschrome wrote: greasy125 wrote: weld a nut to it. just a few little tacks is all you need. then run a bolt thru the nut and it'll press against the case pushing the bearing out. the residual heat from the weld helps loosen everybody up. good luck! -g drop a flat washer in the bottom before you weld a nut in it. That way the bolt is less likely to gouge the aluminum. -g
Positive
2007 Stella 225
Posts: 3547 Location: Rochester, Minnesota |
If you don't have a welder, could you thread a bolt into the center, basically into the cage area. Then heat it up, and tap it out with a slide hammer? Not sure if you could get a hold of it enough with threads and not put to much outward pressure. I've threaded bushings in the past and inserted a bolt then tapped to get them out.
I like the welding idea and it would be an excuse to get my mig welder out. Just trying to thing of a way if you don't have a welder. As others have mentioned, you could cut the cage in several spots where needles are, then twist the cage inwards. Once its no longer round and bent in it should come apart. Its going to be the biggest pain and most labor intensive, but should work. |
But the most important tip is to be very careful as to not punch through the backside of the case! So if you do use the "welded nut" technique, let the bearing cage cool down all the way after welding it. Then heat up the case hot enough for your spit to sizzle. Then try extracting it.
I just took a screen shot from my one of my Smallframe threads. Also it's critical to protect the aluminum case from the hot weld spatter!
whodatschrome wrote: But the most important tip is to be very careful as to not punch through the backside of the case! So if you do use the "welded nut" technique, let the bearing cage cool down all the way after welding it. Then heat up the case hot enough for your spit to sizzle. Then try extracting it. if no love there, then cool, heat case and try again or go to slide hammer. most of the time though, i just use the specialty puller for it. but if i've loaned it to somebody, this is the way i attack it. -g |
Bearings extracted and replaced
Thanks for the tips everyone! I welded a nut to some allthread, found a washer the same size as the bearing, ground if flat on two sides so I could weld it to the bearing. Then used crank puller to pull it out. First welds snapped, second welds held nicely
Posts: 5325 Location: Florence, OR |
