@popgunandy avatar
61 VBB 76 Rally 200 79 P200 80 Sport 100
@popgunandy avatar
I'm connecting the wiring on a VBB1T (6v no battery) and using the scooterhelp wiring diagram
https://www.scooterhelp.com/electrics/wiring/VBB1_VGLA1_VGLB1.pdf
Here's my stupid question: The wiring diagram shows six connections within the junction box, but it's my understanding that the red and grey wires from the loom simply pass through the box since there are only four posts for connections. Do I have that right?
I prefer the mauropascoli diagrams but they don't have one for a VBB1T without the battery.
@mjrally avatar
@mjrally avatar
You should have 5 wires if youre battery less. Red to the harness and then a jumper to the ignition coil. Black to black, green to green, yellow to yellow, blue to blue.
If you have the right junction box, all 5 wires will fit inside them with only the red coil wire poking out separate.
@popgunandy avatar
@popgunandy avatar
Nope, I have six wires coming from the stater and six from the harness.
So does the diagram. I know the stater and harness are correct and so is the four connection junction box. Just trying to figure out how to wire everything up other than colors match each other
@mjrally avatar
@mjrally avatar
I can see now the ignition coil is not the same as the other VBB's I've worked on. Makes sense why its 6 wires.
Ok so looking at the diagram I'd secure the 3 lighting wires at the junction box and then guess which yellow your orange wire goes to. If you have a multimeter you can check for continuity and find it.
Then red and grey go to the ignition coil. It also looks like you have one red wire off the stator with the wrong connector on it. Swap it from a male spade connector to an eye terminal.
@popgunandy avatar
@popgunandy avatar
Thanks very much!
That weird connector is because the wire was too short to reach the coil so I create a little jumper there to another piece of wire. Hokey but it works.
The orange wire is actually a replacement of a black and yellow wire that came off the stater.
[ Time: 0.0107s ][ Queries: 4 (0.0038s) ][ live ][ 343 ][ ThingOne ]
