jimc wrote:
The lights are fed from the AC regulator, but this can't regulate properly without the battery being connected. Check the battery connections.
If you leave the lights bright they will burn out - they are dim normally.
I dont know about that because I have compared it with a similar model and the lights are brighter on that compared to mine. Should I open the battery case and take a look at the connections?
