2019 GTS SuperTech 300 HPE w Malossi kit
I've ordered the shocks, now the anxious wait that I'll be happy with them (be able to adjust to a nice comfort)
Fingers crossed
2007 Vespa 250 GTS
2007 Vespa 250 GTS
Did you buy all 3? How much?
Front + Rear was AU$808 + 89 shipping
Same price as bitubo black (within a few dollars)
@harbinger avatar
@harbinger avatar
Let us know how it goes. I imagine it'll be about the same as the Bitubo's. I went with those (all 3) in red. TBH mostly because I wanted red and my Piaggio dealer had them in stock!
Enjoy! They do make a difference and glad you went with all 3. So what's next?
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
Sell me you old ones!
I went the matt black to suit my grey supertech. brembo on the front will be next
seriously, they're 14months old?
note: the front has a yellow spring
Got them
Yum
Yum
@dooglas avatar
GTS 300ABS, Buddy Kick 125
@dooglas avatar
Tell us how it works out. Usually "performance shocks" and "nice comfort" don't fit in the same sentence.
Any ideas on the plastic ring?
Hmm
Hmm
@mike_holland avatar
GTS300 Super 2023 Beige
Brembo require a special mounting bracket for the front that looks untidy and messy. I don't know what they have for the rear. I went for Frando callipers on my 2018 model. They work as well and look far neater.
those look high quality. I think you will be pleased. a well designed shock does indeed improve both handling and comfort.
'08 Vespa LX80, '07 LX50
Keep debris out of the housing? Or is the fit sloppy?
All installed but not tested (so yes, that preload on the front is very wrong)
Front
Front
the plastic ring rattles. I am tempted to just cut it off. have just emailed sip.
@crazycarl avatar
@crazycarl avatar
Those look nice and SIP branding carries some assurance the product has had decent R&D.
One thing I noticed when I upgraded to the Malossi shocks was the thickness of the springs and the progression of the coils - seemed much beefier than the OEM.
At the same time I upgrade to Poly bushings in the rear. Clauss Studios make a set for a very reasonable cost. They do a very good job of tightening up the play in the rear.
SIP vs Robot's Bitubo install left shock spacer
who got it right?
sip
sip
robot bitubo
robot bitubo
since they are the same as Zelioni I'm curious who actually designed and manufcatures them. SIP has been selling shocks with their name for several years so I feel I can have confidence plus they have gone through germanys strict TUV / ABE stuff so should be solid.
I did notice the diameter of the springs is significantly larger, meant that although I could get the original right rear off with out removing my Arrow exhaust there was no way to get the sip back in.
I considered the clauss ... thinking I might get them next year when I am planing on replacing the brakes with brembos. not now as I want to experience the sip first and also shipping from germany is way expensive
is this still considered a good way to set preload https://modernvespa.com/forum/wiki-proper-way-to-adjust-shock-preload ?
seems to match other stuff
@amateriat avatar
@amateriat avatar
How Timely...
The time is approaching when I'll need to switch out Melody's original shocks, and the mention here of SIP's own branded shocks adds yet another wrinkle for me: I'd pretty much decided to bite the big pricey bullet and have Bitubos all around, but then came word, via my dealer, that Öhlins has thrown its (likely crazier-expensive) hat in the scooter-shock ring, eventually reaching the States...eventually. No idea how much they'll cost, other than the likelihood that they'll come in North of Bitubo's prices. Another unknown is compatibility: there's a publicity photo from Öhlins clearly showing their front shock on a GTS with ESS front end (like mine), but nowhere else can I find information to confirm that what they'll ultimately be offering will include this compatibility. With my dealer, a Bitubo set will have me in for about $1k, including installation. Not certain what Öhlins can offer over Bitubo besides slightly extra cool-factor (for the 2% of people who'd notice, let alone care, and only in terms of the front unit).
⚠️ Last edited by amateriat on UTC; edited 4 times
@amateriat avatar
@amateriat avatar
Seems sound to me: my problem is that springing on my current set is now quite weak at max preload...and no, in spite of our Current Shared Calamity, I haven't picked up that much weight.
@crazycarl avatar
@crazycarl avatar
Re: How Timely...
amateriat wrote:
The time is approaching when I'll need to switch out Melody's original shocks, and the mention here of SIP's own branded shocks adds yet another wrinkle for me: I'd pretty much decided to bit the big pricey bullet and have Bitubos all around, but then come word, via my dealer, that Öhlins has thrown its (likely crazy-expensive) hat in the scooter-shock ring, eventually reaching the States...eventually. No idea how much they'll cost, other than the likelihood that they'll come in North of Bitubo's prices. Another unknown is compatibility: there's a publicity photo from Öhlins clearly showing their front shock on a GTS with ESS front end (like mine), but nowhere else can I find information to confirm that what they'll ultimately be offering will include this compatibility. With my dealer, A Bitubo set will have me in for about $1k, including installation. Not certain what Öhlins can offer over Bitubo besides slightly extra cool-factor (for the 2% of people who'd notice, let alone care, and only in terms of the front unit).
The Malossi RS24 shocks are made by Paoli, if that sways you at all.
@amateriat avatar
@amateriat avatar
Re: How Timely...
In fact, I looked up the Malossi shocks after posting here...totally forgot about them. They are now at the top of my shortlist.
⚠️ Last edited by amateriat on UTC; edited 1 time
@harbinger avatar
@harbinger avatar
I went with Bitubo front and rear and am happy with them. TBH any of the high end performance shocks are going to better than stock and reviews will vary by individual.
who got it right?
robots look straighter in alignment, the sip way looks like the bolt and shock will be in a bind
old as dirt wrote:
who got it right?
I disagree. Look at the photo of the original shocks at https://modernvespa.com/forum/wiki-proper-way-to-adjust-shock-preload and you'll see that the vertical center line of the shock is to the outer/left side.
I've also attached a screenshot of the bitubo manual http://bitubosrl.zucchetti.com/Bitubo/dms/Documenti%20MAGO/Istruzioni/SC180WMB01-02_Rev03.pdf which also shows the spacer should be on the wheel side, not the outer side.
bitubo manual
bitubo manual
steelbytes wrote:
old as dirt wrote:
who got it right?
I hear what your saying but the spacing on the sip is angled. the top space above the bolt on the left is larger than the space at the bottom on the left, this tells me the shock is at an angle.
1 year later and still happy.
Slightly disappointed that the satin/matt black has faded to brown/bronze.
GTS300ie
GTS300ie
I was wondering how the shocks performed in terms of comfort. Are they progressive?
Do they tend to bottom out? etc.
Yes they're progressive.
I have them set just perfect for me and they don't bottom out. Getting the settings right matters
@tmessolo avatar
VESPA GTS 300 HPE ABS/ASR E5
@tmessolo avatar
But still the bronze style is cooler than the total black..nice set up man.
The only thing that i would worry about is that in case of absorber fault or service (maybe no maintenance needed though) would the dealer fix it or SIP will have to cover it?
This is mainly the reason that i would go with Bitubos.They have a good aftersale service as a brand.
Well I've done 20,000km on them in the last year, a lot of that on very very bad unsealed roads sometimes signposted as 4x4 only. Still going fine.
The reason i decided that i could have reasonable confidence in the build quality is two reasons: I'm pretty sure they come from the same factory as the zelioni who had been selling them for longer than sip had and also because sip had been selling their brand suspension for several years for older Vespas such as the px. So yes it was their first foray into gts suspension but i crossed my fingers and haven't regretted
@kimpossible avatar
Tethys - 2012 GTS 300
@kimpossible avatar
Thanks for the follow up!
[ Time: 0.0129s ][ Queries: 4 (0.0049s) ][ live ][ 339 ][ ThingOne ]
