@antoniotriopx avatar
Px221
Px221
Hi guys I'm new to the page but have followed some conversation in the past . Great stuff.
I recently seized again with my px 221 malossi
Set up :
Malossi 210 - 2013
Mazzucchelli 60mm mushroom shaped
Jl rh pipe
30 mm dell'orto
Malossi reed
Last 2 times I seized I had a failed , (chunk came off ) Of Crank case seal That got stuck in in the piston, and I let you imagine the conclusion.
Is anyone of you guys have had this problem before?
First seizure balanced shaft, was a tick out, this time haven't fully open case yet but top end is off and can see damages including the seal stuck in the cylinder port.
@greasy125 avatar
@greasy125 avatar
actually can't see much of anything. maybe a little bit wider shot?
and what's the actual question? i mean, besides has anybody else seized or blowed up a performance motor?
-g
@mjrally avatar
@mjrally avatar
I've seen two times the metal clutch side seals come out of the case and tear up/shatter. If that's what you're dealing with you could try a smear of white loctite/cement so it stays put.
Px221
Px221
Yes that's especially what's is happening to me engine.
The question is why is happening?
Px221
Px221
Picture is to show That the seal is gone from a close engine.
And the question is why is happening?
Is it because crankshaft is ot of balance or other possible reason?
Px221
Px221
Px221
Px221
Jet Eye Master
Jet Eye Master
This is one of the problems with performance engines. When the metal clutch side seal comes out the first time, something may have been wrong with it. Twice and its the casing. Its never the crank.
If it was a metal Corteco seal its more likely to come loose. The metal Malossi ones fit tighter. You're not the first; this has happened plenty of times.
Now you have had two seals come out, there are no more metal seal choices for you. If when you split the engine its all generally ok, the best chance of a seal holding in is a full rubber seal with a flat edge. And stuck in with Loctite 603.
@mjrally avatar
@mjrally avatar
In the future when you need to install oil seals, buy this bearing tool and use it to help install the seals. I've found it works better than another else to get the seal in tight (both metal and rubber) and get it flush. Works great with either type of seal especially those pesky metal lipped ones
@chandlerman avatar
Innovator
102 Days Since Last Explosion
Innovator
@chandlerman avatar
I 100% second this. I use that same bearing punch along with Loctite 603 on all those metal seals and it works great.
@safis avatar
@safis avatar
That SIP tool is not "right" though. I have it and it's smaller than the seal and the bearing's OD. It's only useful for installing the bearing in the cases. Also, newer metal seals need to protrude 0,5mm or they'll rub on the bearing center race and pop out. I had to make a tool for fitting them. Plus Loctite 603...
@rowdyc avatar
@rowdyc avatar
Do you have super strong clutch springs? Those springs may not help the clutch bearing and seal either.
Px221
Px221
Thanks guys.
These are great tools.
I have been thinking about purchase some thing like that.
I feel better now in a way as I'm not the only one with this problem and for me opens the door at more specific handlings.
Thanks for the info very much appreciate your guys time .
Last time I rebuild this engine (last year) i believe I didn't grind back that metal seal.
Would that make it pop out?
Also I have noticed that the seal has been rubbing on to the bearing because of marks behind.
So should I try one more time?
Grind it back and loctite 603?
If not where would I get the rubber seal? To any bearing place ?
Jet Eye Master
Jet Eye Master
No.
Here is a picture I have seen many times. That is a metal viton Corteco seal. They are not really the best choice for a tuned engine.
Now your engine has spun 2 seals the engine casing is now damaged. It's not the end of the world. There is a long list of options.
The next thing to try is a full rubber seal. The BGM one is the tightest fit I have found.
You don't say what year your scooter is. If the crankcase has the groove, it would have used the full rubber type oil seal. I can second the advise to use the BGM seal. I used one in my MHR221 build, which turns out had the groove where the seal fits. I had tried to use a Corteco brown metal one, but couldn't get it in without distorting it's outer edge
https://www.scooter-center.com/en/oil-seal-31x62-1x5-8/4-3mm-bgm-pro-fkm/viton-e10/etahnol-resistant-rubber-brown-used-for-crankshaft-drive-side-vespa-px-1984-rally180-vsd1t-rally200-vse1t-sprint-veloce-150-vlb1t-294260-super150-vbc1t-412374-ts-vnl3t-bgm1004?number=BGM1004
Px221
Px221
I have the original clutch with Malossi springs and discs
I also have the cosa clutch but not install because I haven't been able to get it to work properly
@ginch avatar
@ginch avatar
Pretty sure it's Freakmoped who says all the metal seals need to be ground a little on the edge to make sure they don't touch either the crank or the bearing. I was under the impression the Malossi ones don't need it however.
There is also available from Scooter Center some shims to hold the clutch side bearing tight and not move sideways at all.
You can buy the rubber seal from GPS Imports in Vic.
@svint1 avatar
too many
@svint1 avatar
too many
Hi!
Are you sure that metal seal is the correct for that casing?
There are two versions of the casings. -with and without "lip" where the sealing sits.
If there is a small groove where the sealing sits, you have to use the rubber ones, not metal ones.
-and vice versa.
In addition the metal sealings are normally too thick, so I normally grind them down a milimeter or two. -can't recall the exact number, but google probably do.
-then you're sure that the sealing is flush with the crankhouse and not interfering with the bearing...
All the best and good luck!
Ø
Thanks guys.
Px221
Px221
Svint1 wrote:
Hi!
-and vice versa.
Ø
Actually you have a super valid point.
My vespa engine is a 1985 Built so i just found out that it's the rubber seal the correct one..
I have been sold for 4 times the wrong one ( metal one)🤐
The crank is out and It is being Correte and Tig welding.
Hopefully my nightmares are over soon.
Thanks guys.
@108 avatar
V range 50s
@108 avatar
V range 50s
Yeah, you need to grind the metal seal down as the gents here are mentioning... I aim for 3.6mm height of the whole seal (not the sealing surface, that's like 3.4mm or something... there's a slight angle to the seal)
And before installing the crank, you can check if the bearing is rubbing on the seal by just turning it...
[ Time: 0.0112s ][ Queries: 4 (0.0039s) ][ live ][ 341 ][ ThingOne ]
