1965 Vespa VBB2T, 1960 Allstate Cruisaire
Hi I checked the search and did not really see anything to bass a plan off of. I just picked up a 65 VBB That desperately needs new tires and tubes and Wheel Refinishing. I know how to break down small frame wheels but for my bike do I unbolt before wheel bolts on the front? How about the rear? Can any one step me through it? Thanks again
Undo the 4 big bolts that will remove the hub cover.
Take the tires and rims off the bike
Then Undo the rim/wheel nuts
Deflate the tubes a bit
Then break the bead on the rims
Separate the rims
When u go to put the new tubes in put just a touch of air in them... not too much just enough so they have a little form otherwise they'll get pinched when you tighten the screws on the rims.
I coat my tubes with baby powder too. Helps them slid in nicely. Soap and water around the tire beads as well will help them slide on a bit easier too.
Not too bad
One busted knuckle Crying or Very sad emoticon
Don't need no stinking motorcycle work table
@rowdyc avatar
@rowdyc avatar
After a while of working on these, that floor gets harder and knees and back get sore. Laughing emoticon
Great job on the wheel split!
[/quote]After a while of working on these, that floor gets harder and knees and back get sore. Laughing emoticon
Great job on the wheel split![/quote]
seriously. I have about an hour a day in me. I gotta get a lift. My spine can not handle that 45ยบ angle bend at all.
[ Time: 0.0105s ][ Queries: 4 (0.0030s) ][ live ][ 343 ][ ThingOne ]
