Et4
Et4
Hi , I'm new here and new to scooters , I have a 2001 Vespa et4 which I'm enjoying ! When I first start it up I let it warm up a bit then when I ride off it the engine vibrates under load ie pulling away or going up hill , is this a normal thing or is there a problem? Many thanks Russ
@juan_orhea avatar
S150 '09, Beo 500ie '08
@juan_orhea avatar
This type of shuddering is an indication that the CVT could use cleaning, inspection, and possibly some new parts. The belt may be slipping in low gear, the clutch plates may not be engaging well simultaneously, etc.
Et4
Et4
Blimey that sound like it could be loads of things ! It seems to stop when it's warmed up , could this point to anything specific ?
@miguel avatar
@miguel avatar
I'm unfamiliar with the ET4 but if it was a GTS, I'd say the clutch bell is glazed which causes the clutch to slip and grab when first starting off. The solution is to use 180 grit sandpaper and scuff off the glaze from a bell housing Where it contacts the clutch shoes. No need to Scuff up the clutch shoes. You can probably find a YouTube video on how to do this on the ET4.
Best
Miguel
@juan_orhea avatar
@juan_orhea avatar
This kind of stuff is routine maintenance on a 20-year-old scooter. It really isn't difficult to handle with a few tools on a DIY basis, nor are the parts particularly expensive - if they even need replacing. Mechanical things wear out, need adjustment, and get old, it's a fact of life. If you aren't willing to deal with it then you'll need a good relationship with a scooter mechanic or you should be riding something newer.
@madison_sully avatar
Does it happen if you take off WOT?
Et4
Et4
sorry WOT ? I'm not sure what this means
Et4
Et4
I'm quite happy to deal with it , I ride a 20 year old motorbike which I do my own maintenance on , I'm an electrician and by no means a mechanic but I've learned, as I said I'm new to scooters and was after some advice , I'm quite happy to carry out work required if pointed in the right direction!
It sounds like the clutch is juddering as you move off. This can reduce or even mostly go away once the motor is hot. The cure, as mentioned above is to clean out the clutch drum of dust, BUT make sure to sand very carefully the clutch pads as well. No good just doing the drum without the other. That normally cures the issue. If the clutch pads have less than 1mm of friction material left on them, you should replace the clutch. Otherwise it might be slipping and juddering when the motor is hot too. Good luck, let us know how you get on. Of course it could be something else but this is the most likely.
⚠️ Last edited by Stromrider on UTC; edited 1 time
Et4
Et4
Best
Miguel
thank you for your advice , I'll try and have a look at that 😀👍
Et4
Et4
thanks for your reply , I'll definitely post an update ! 👍
Et4
Et4
Thanks for all your replies, seems like a really helpful forum I've joined ! 😀👍
WOT = Wide Open Throttle.
It's good for scooters' clutch to get up and go, as it helps to avoid clutch glazing.
Et4
Et4
ah right 👍 it's actually worse if I open it right up !
@juan_orhea avatar
@juan_orhea avatar
Oh, you're in good shape, then. Your "blimey" response concealed your experience! As you'll see there are only about seven parts of interest in the transmission: two halves of the engine-side pulley, one that moves and one that doesn't; the centripetal rollers or sliders that move the pulley; the belt; the clutch bell; the clutch assembly: and the contra spring.
Et4
Et4
nice one , thanks 👍
@wheelman-111 avatar
2010 S50 Modified "Punkin"; 2003 ET4 Malossi 187 "ISO"
Greetings:
Don't know where Devon is exactly, but despite the good quality and durability of the stock Piaggio clutch ($130 here in the U. S. and A.) the added performance capacity of the $160 Malossi MHR Delta Clutch and Bell is a better unit. This is particularly true if you ever plan to go Big with the Malossi 187 cylinder. For every scooter I've owned, the Delta is the go-to unit for its higher power handling capacity and cooler running ventilated bell.
@miguel avatar
@miguel avatar
Russ34 wrote:
Best
Miguel
Actually, I'm going to defer to Stromrider. He is a MASTER mechanic and MUCH more knowledgable than I am. If he says to scuff up the clutch shoes as well as the clutch bell, do it.
Thanks for the correction Stromrider.
Best
Miguel
@amateriat avatar
@amateriat avatar
Might this be akin to the fabled "Italian tune-up?"
⬆️    About 28 days elapsed    ⬇️
Et4
Et4
Hi , just a quick update , I removed the plastic cover on the engine case covering the clutch and sprayed some brake and clutch cleaner in thru the holes in the clutch housing and what a difference it's like a different bike , the clutch must have been full of dirt ! Many thanks for your help everyone! Cheers Russ
@pinkscooter avatar
@pinkscooter avatar
Russ, Robot tells you everything you need to know. It sounds like you need to service your CVT.
"https://www.youtube.com/watch?v=jiEA9SXhtng"
Et4
Et4
Ah right , is that not it cured then ?
[ Time: 0.0126s ][ Queries: 3 (0.0063s) ][ live ][ 313 ][ ThingOne ]
