While replacing my fuel pump ( see topic-replacing the fuel pump, the story continues!) I had a good look round the engine for possible clues to my problem, and I noticed that the rear mud flap has a chunk torn out of it, so I bought a second hand one with the idea of replacing it, while the engine has dropped...
The mud flap is secured by one single bolt above the flap, that must have had a poor time in the 7 years its been there as it's welded tight from the years of rainwater splashing around...
facebook mobile upload
Ok, I thought "its just a simple task of getting the bolt off...but try as I can, it just won't move, now up to a point where it's starting to round off... Using a dremmel cutting disc, I cut a groove into the top of the bolt and tried to use a screwdriver after soaking it in WD40 for 2 days... it broke the tip of the screwdriver..... even using a fine tipped blowtorch didn't move it!
Can anyone recommend a powerful spray you can use to free up the bolt, before it's completely rounded off??
Graham
