Attila wrote:
... when Greasy sees this, he issues an excommunication ...
When I have to use a bolt extractor I first make a guide hole with a very small diameter (2 or 3 millimeters) but to avoid slipping the bit from the center I use a graver (if the blow does not compromise the piece around).
The drill bits:
Drill bits range from drill bits for iron and metal to bits for wood. Each type has a dedicated abbreviation to recognize it, buy high quality tips!
For holes on stainless steel or titanium a HS / HSS CO DIN 338 twist drill, medium speed of the drill and coolant on the hole, operation to be done in two people and without insisting too much.
I'm dreading to think what Greasy will say about this...
Anyhow, the bloody bolt has seized completely, and now that I can see it more closely, it would seem the aluminium casing has welded itself to the hardened steel bolt, making it impossible to remove. After all, nearly seven years of rain, has taking it's toll on the bolt, which makes me beg the question- if the bolts are only holding a plastic mudguard, then why use hardened steel bolts with an alloy casing? surely, it would be cheaper and easier to use maybe plastic bolts, or something similar seeing as they will be mostly exposed to the rain seeing and it's location is near the rear wheel?
Just like a lot of parts used to build the Vespa, it does make you wonder about the build quality.. sometimes you have to take off the rose coloured spectacles to see the faults - I remember a former member- Bill Dog, tore a strip off Piaggio for the shoddy quality of the paintwork, and I think that's what deterred him from getting another one again, as well as other faults and I can vouch for a number of issues I've had in the past, again with the quality of the components used to build a Vespa, that sometimes really try my patience with Piaggio...
I'm not saying that Vespa's in general are unreliable- sales totals will tell you that, and they do have history on their side and have almost become a fashion accessory, but for christ's sake Piaggio, don't cheapen the name, just to cut a few corners to save a dime or two...
Graham
