I hate electrical problems!
That's mostly because I don't understand them. Sure, I know the basics of how a 12 volt DC system works but what I don't understand is how it DOESN'T work! That what I'm dealing with now. The electrical system on Spermy (https://modernvespa.com/forum/topic168825?highlight=spermy) died and I have no idea why or what to do about it.
In November I shut down Spermy for the winter, disconnected the positive and negative battery cables and attached my battery tender. Then in early February I reconnected the cables, more or less, and went for a ride. I found out later that I had connected the negative battery cable and the positive cable for the Nautilus horn but I forgot to connect the main positive battery cable. As I left the house, I saw that all the DC lights (except the neutral light) got really bright and then went out. I reconnected the positive battery cable but all the lights (except the neutral light) still don't work. I checked the fuse of course but it is still intact and the bulbs are still good so I have no idea where to begin looking for the problem. I haven't sat down and tested the continuity of the wiring, mostly because I don't know where to begin.
Might this be a problem with the voltage regulator? (If that's a dumb question, please refer to sentence #2 above)
I'd appreciate any suggestions.
