First series v90 with 14mm gudgeon pin used a
bushing on connecting rod small end.
Later series and all models after, like the primavera, v100, used a 15mm gudgeon pin with needle bearing on small end of connecting rod, I believe.
Unless someone bored out the small end of the con-rod and replaced with a custom bearing.
