Here are a set of Sprint Veloce cases that someone had used JB Weld on them. I took a Starret pin removal punch from inside the cases and used a little tap from a hammer and the temporary JB Weld came right off.
Anytime you break through or want to increase the thickness of the wall or width of the gasket surface, the real solution is to TIG weld up and mill to complete.
These cases are now ready for a VMC 177.
