2008 Vespa LX50
2008 Vespa LX50
I would appreciate any help/advice you can give me on a 2008 LX50 (450 miles on it) that will not start.
Cleaned the jets on the carburetor and everything looked in order. I have been trying to start it with a full battery charge. However, it simply will not catch, I can smell fuel so I assume the jets are clear now.
Thanks for any help.
@pinkscooter avatar
@pinkscooter avatar
Do you have spark? You need 3 things, fuel, spark and compression. Compression at 450 miles probably isn't the issue, you think you have fuel so start with spark then check that the plug is wet. No spark could be many things. If you do have spark a little starter fluid sprayed in the air box should get it going.
[ Time: 0.0076s ][ Queries: 3 (0.0016s) ][ live ][ 313 ][ ThingOne ]
