Took my Scarabeo to a Triumph dealership this afternoon for its annual inspection. It expired last month and my regular guy, an extremely local independent repair shop who stopped working on motorcycles but continues to inspect them out of a love for the machines, didn't get his shipment of stickers for March.
The Triumph inspector takes one look at my Beo and says the front fork seal is leaking, so it fails inspection. There is a small oily smudge below the tube that I suspect is simply grime, but if it's a leak it's a very slow one - the scoot has not been washed for over a thousand miles. Either way, I remind him that fork condition is not part of the NY state motorcycle inspection regimen.
He says it is, and surmises that oil could leak from the fork down onto the rotor and brake pad, creating a safety concern, and since it's a safety inspection, it fails.
I'm pretty sure the NY inspection is actually an equipment checklist, not an open-ended safety inspection intended to flag things that "could" happen, so I ask him one more time if his observation is a maintenance recommendation or an inspection requirement. He repeats that it's a requirement.
I repeat my assertion that fork condition is not an inspection item and leave, annoyed, because I think he's misrepresenting the inspection rules to drum up repair business, and the tactic probably works because an awful lot of motorcycle riders around here do not know one end of a wrench from another. There is nothing on the NY DMV website referring to motorcycle fork condition, and I've been referred to this document before as the basis for the inspection criteria:
https://dmv.ny.gov/forms/mv529b.pdf
Further Googling reveals:
* several shops claim fork seal leaks fail inspections
* lots of individuals claim these shops are wrong and deceitful; that the criteria for inspection is cut-and-dried and limited to valid registration; working lights for brakes, turn signals, license plate, and headlight; working horn; 2/32" of tire tread; and at least one rear-view mirror.
So, is the Triumph guy drumming up business because motorcycle inspections are only $6, or is my usual inspection guy a slacker?
Either way, the Triumph guy acted like a sphincter and offered no evidence when I questioned him, so I'm not going back even if I ever decide to buy a Triumph, and I've wiped down the area below the fork seal and will continue to observe it for signs of an actual leak.
