Hi
I have a lml vespa nv 1989 model which is almost similar to vespa px. I am currently restoring the vehicle and it's the first vehicle I am trying to restore. However I came across some difficulty in installing the ignition assembly and front fork. Any help on these will be so helpful.
I would like to know if there is a correct position for the front fork to go inside (like wheel should be extreme left or should be aligned towards us) ? I am asking this because I see a curved place and a notch in the fork and I believe it's where the lock mechanism comes into place.
Also how should we determine the position of the lock block. ? Normally it goes in with the T shape looking outward of the scooter isn't it ? If that is so, what should be the switch position of the barrel ? Should that be in on/off or in lock position.
And in the ignition switch bought by me, the switch is able to rotate 360 degree ? Isn't that faulty ? I guess there should be only 3 lock rotations and in the on position, ignition switch should pass the continuity test isn't it ?
Regards
Praphul
