@black1999 avatar
GTS300
@black1999 avatar
GTS300
Hi Guys. GTS owner from Taiwan.
My GTS was a 2014 used which I got for 1 year now.
Since one month ago, I am having problem when I turn the key the first time, the Engine light will on, LED 1 long 2 short and stay on, can't turn the starting motor, but when I turn the key again, it's ok.
After parking few hours, the problem will be back.
I then see someone mention the red key, so I tried it and it was good for 1 week.
Then till this morning, the problem stays and the red key won't work either. The battery is good but I guess I will also charge it today just be sure...
Does someone having a solution? I am thinking to change the coil on the lock but I still have doubt.
It can be as simple as the electrical connections between that coil (the 'antenna' or 'aerial') and the ECU (throttle body).
Try re-seating the connections first, before purchasing anything.
@black1999 avatar
GTS300
@black1999 avatar
GTS300
Update:
Replaced the aerial today, everything seems back to normal.
For now.
Good fix. Thanks for reporting back.
[ Time: 0.0095s ][ Queries: 3 (0.0019s) ][ live ][ 313 ][ ThingOne ]
