Super 150
Super 150
Which badge should my 1975 150 Super have on the back frame ? at present it doesn`t have one, the front badge is the flat one probably glued on. So would that be correct and if it is presumably the same for the rear and not the chrome script...
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
This is the rear badge for a 75.
It goes through two holes and is held on with clips. The front badge is supposed to be peened on, but adhesive works fine.
Super 150
Super 150
Thanks, hmmm ! no holes on mine, maybe it could have lugs ground off and glue it on ? or just not bother.
@qascooter avatar
@qascooter avatar
Shoe-goo and 24 hrs later it'll be stuck on good. BUT you can peel it off at a later date without hurting the paint. Magic stuff that shoe-goo...
Super 150
Super 150
Shoe-goo ? what is an equivalent in the UK do you think ?
VNB VSC VMA VSX - o9c vbc vmb
Ripcare is a similar EU product. (Make sure to get the clear version.) But, I'd think you could grab some shoo goo via amazon for sure.
[ Time: 0.0106s ][ Queries: 4 (0.0029s) ][ live ][ 313 ][ ThingOne ]
