@mitleider avatar
2024 GTV & 2024 GTS Supertech
@mitleider avatar
Afternoon, all!
I've seen a number bed of posts regarding recommended technique for removing the factory stickers from glovebox. Most suggest using moderate heat from hairdryer, then follow up with Goo-Gone, or similar.
My worry is that Goo-Gone or mineral oil may leave a shiny residue. Any suggestions for a process for matte paint finish would be greatly appreciated!
@fudmucker avatar
@fudmucker avatar
I don't hve experience of matt paint, but a hairdrier followed by eucalyptus oil or kerosene / paraffin has always worked for me. A follow-up bike wash should remove the last traces completely.
@tidwillow avatar
GILERA FUOCO II & GTS 300 SUPER
@tidwillow avatar
I removed my factory stickers on my matte black bike with the hair dryer waft method. Those stickers just wanted to come off with ease. They came off so easy I put them on the inside of the glove box when taken off. Don't overheat and I think you'll be fine. Good luck!
@attila avatar
@attila avatar
The problem is the residual glue that may remain, in which case a non-abrasive cleaner for opaque surfaces (Motul Matt cleaner or similar) is used.
@mitleider avatar
@mitleider avatar
Thanks to all...! Will g8ve it's go today......
Vespa Elettrica, GTS 300 HPE
Please share your experience and any tips you uncover.
@mitleider avatar
@mitleider avatar
Update
Good morning, I followed advice here, used hairdryer on high setting, judiciously. The glove box label came off cleanly, on both scoots.
The same technique on the lower panel did not respond easily. The label peeled off in little bits, took patience, and left behind a lot of goo. Using alcohol dissolved the glue residue, and followed with Dr Beasley Matte Paint Cleaner then Finish. Super great products. Perfect results.
@attila avatar
@attila avatar
ooookkay..!
Gts 300 notte
Gts 300 notte
Re: Removing stickers off matte finish paint...??
Mitleider wrote:
Afternoon, all!
ive used goo gone on everywhere there was a sticker on my gts (notte - all matte everywhere). no residue, nothing left over. worked perfectly.
to get stickers off i just started a corner and went slow..
like really slow, cause they are awful stickers, lol but do able just with your thumbs
[ Time: 0.0102s ][ Queries: 3 (0.0040s) ][ live ][ 313 ][ ThingOne ]
