I run a 93 octane (R+M)/2, also called AKI Anti-Knock Index, in my scoot here in the states. It works fine.
TLDR: Aspen is using an Isooctane instead of ethanol blended with their gasoline feedstock to achieve their stated octane rating. Who knows what quality the oil they are adding to the pre-mix. I would have no issue running an alkylate gasoline (even at a reasonable price premium) but I would not run the Aspen pre-mix for my tuner Vespa engine.
I have gone down the fuel rabbit hole before, but will keep this higher level.
Below is a simplistic explanation:
Gasoline out of the refinery tap is lower octane than what is needed at the pump. Therefore you need to bump up the AKI before selling at the pump. To increase AKI you need to spike the gasoline with one or more of the following: alcohols (methanol, ethanol, etc), ethers (MTBE, ETBE, etc), or antiknock agent (Tetraethyllead aka TEL aka lead,
Isooctane, etc).
Let's focus on Isooctane. "Isooctane is produced on a massive scale in the petroleum industry by
alkylation of isobutene with isobutane. The process is conducted in alkylation units in the presence of acid catalysts."
Wikipedia: Isooctane (2,2,4-Trimethylpentane).
Aspen Fuels Website wrote:
Aspen 2 is engineered alkylate fuel sold ready-mixed at 50:1 with fully synthetic biodegradable oil.
Yay, we got there. Alkylate = Isooctane. My guess is that it cost more to use an alkylate versus ethanol to spike octane. However if you can charge a premium to a customer who cares about having non-ethanol fuel then it is a win win.
Aspen 2 is largely free of hazardous components such as benzene and other hydrocarbons.
STFU with your marketing crap, this is a fuel which is made up of almost entirely of hydrocarbons. /end rant
Now to the oil portion of their premix. I think what oil you run in a 2 stroke is very important, but maybe I bought into the industry's marketing hype. I didn't see Aspen list out the oil they use and what standard is tested to. I would be worried they are more concerned about pushing the environmental angle than the performance result. See the link further down about 2 stroke oil.
If you want to join the rabbit hole below are 2 great links about 2T oils and 2T gasolines:
Klemm Vintage: About Two Stroke Oils and Premixes
Klemm Vintage: About Gasolines and Octanes for Vintage Two-Strokes
Disclaimer: I'm not in industry, and did simplify some points. I could be incorrect about the simplifications and I am willing to learn.
