Vespa BV 250cc
Vespa BV 250cc
Have a Leaking puddle underneath the front wheel not sure what i should replace or not just bought it. Cracked attachment i noticed where its leaking too. Seems like grease on the floor? Anyone know? Thanks
@wheelman-111 avatar
2010 S50 Modified "Punkin"; 2003 ET4 Malossi 187 "ISO"
Greetings:
By the quantity, I'd guess brake fluid. Brake line or fitting is incontinent or it's the contraption that locks up the front end if it's an MP3.
@jkj-fz6 avatar
@jkj-fz6 avatar
It looks like water. Sure you didn't ride in the rain? Or maybe it's condensation.
@burt37 avatar
GTS 300 SS BB
@burt37 avatar
GTS 300 SS BB
It would have helped immensely, if he took the picture before washing the whole thing..
@jkj-fz6 avatar
@jkj-fz6 avatar
Doesn't quite look like a banjo bolt to me. Perhaps the speedo cable and clamp?
All the liquid looks like it's beaded up like water, not spread out like oil.
Vespa BV 250cc
Vespa BV 250cc
It was leaking right where the crack is on that cable. Seemed like it was grease. Doesn't leak just sitting there, but after i rode around and parked it.
Vespa BV 250cc
Vespa BV 250cc
Sorry i rinsed it off then took the pic. Didnt know about the forum till later. ill take another pic of it tomm, but the cord was all greasy right where that crack was and came down the wheel and left a small puddle. couldn't smell any coolant or anything.
⚠️ Last edited by Kwebb543 on UTC; edited 1 time
@jkj-fz6 avatar
@jkj-fz6 avatar
Could be grease.
That can't be a brake cable; it's on the wrong side. My guess is it's the speedometer cable. A little grease and a small crack in the rubber boot isn't anything to worry about.
Put a sheet of paper on the floor and try to collect more of the stuff. Enough to tell if it has a color to it.
And get a picture of the cable where it ends at the wheel hub so we can determine for sure whether it's a brake line or speedometer cable, or something else.
⚠️ Last edited by JKJ-FZ6 on UTC; edited 1 time
Vespa BV 250cc
Vespa BV 250cc
Yeah im 90% sure it was Grease and your right its not on the other side of the brake cable. Like you said speedometer cable possibly. Didn't know if i should worry about it. just saw a crack and grease on the ground after i took it around the block for a little bit. Was really hot out today in Florida too so maybe that has something to do with it too. thanks for the quick responses guys. Much appreciated.
@burt37 avatar
GTS 300 SS BB
@burt37 avatar
GTS 300 SS BB
The crack is on the rubber not the cable itself..
But if grease has come out, water eventually will get in creating problems..
Speedo cables are not that expensive or hard to replace..
[ Time: 0.0105s ][ Queries: 4 (0.0025s) ][ live ][ 313 ][ ThingOne ]
