I a s riding home and while in 3rd gear the rear wheel seized.This is the third it has happened and had it checked and repaired twice. The Kickstart is stuck but the rear wheel moves .Can somebody please tell me the issue? The last two times it froze in third,maybe I should be in 4th I? dont know.
Hi, sorry to hear this. We really need some more information on this. However, it may just be you have used either too much oil in the petroil mix, or too little!
The carburettor may also be jetted or adjusted incorrectly. The throttle valve needle may be set incorrectly causing the engine to run too lean.
Other things that may cause it are that the piston rings have not been gapped correctly causing them to expand too much when the engine gets hot.
There are other things too such as leaking crankcase seals that can cause the engine to run too lean. Running too lean can cause the engine to overheat and seize.
What spark plug are you using?
We need to know how much work the bike has had carried out recently. Did they rebore the cylinder, replace the piston and rings etc? Who did the work? Was it you or a friend or a shop?
Look at page 3 towards the bottom, developed and air leak and ran lean then seized. The top of the piston is very clean and my cylinder head temperature gauge showed I was getting hot. If you can get a cylinder head temperature gauge it can help you notice when this is happening.
All Content Copyright 2005-2024 by Modern Vespa. All Rights Reserved.
