@valvitola avatar
2018 GTV300 SG, 2012 LXV 125ie 2V, 2015 Primavera 3V 150ie and V90
@valvitola avatar
Good Morning! I have a V9A1T, and I need to replace the original piston. while there I was wondering if I could replace the cylinder with a 130cc or malossi 136cc. If I do that, can I keep the rest stock or do I need new crankshat and carburetor?
Thank you in advance!
@valvitola avatar
@valvitola avatar
This is the current Carburator, Dellorto SHB 16/16, do I need to get a 19/19?
You already have the longer crank in your V90, but you will want at least the 19 carb and manifold plus a better pipe than stock to take advantage of the new cylinder.
@moto64 avatar
@moto64 avatar
I think even with the stock pipe you will see a nice bump in power but keep in mind you will not be allowed to ride in some parts of Germany.
That's a hi end huge port cylinder. Your case ports are much smaller and you may do as well with a milder Polini or even DR 130 kit, but you will still want the bigger carb even if you start with your stock exhaust.
https://www.sip-scootershop.com/en/product/racing-cylinder-dr-130-cc_10008000
I think the only way to justify that Malossi kit is with a lot of case welding and grinding, bigger carb than a 19 and using that cylinder inlet and a reed valve, a really good pipe, a stronger clutch, probably a racing crank and maybe some gear work too, at least your primaries. Oh, and a hot ignition to match please... CHT & EGT would be a good investment about now too. How's your shocks, brakes and tires???
@swiss1939 avatar
@swiss1939 avatar
Lol.
@poidog avatar
Drama Free
79p200e 66smallstate 85pk50xl 84p125ets 63GL
Drama Free
@poidog avatar
What V oodoo said.
+1 on Polini mono or DR with 19.19 carb.
@valvitola avatar
@valvitola avatar
You guys are the best! Will buy the DR 130.
I am confused about which crankshaft to get, I need to change the existing one, any recommendations? Any other part that I need to change?
Found this one:
https://www.sip-scootershop.com/en/product/crankshaft-mazzucchelli_45104000
⚠️ Last edited by ValVitola on UTC; edited 1 time
@valvitola avatar
@valvitola avatar
This Banana exhaust looks nice, nicer than teh Polini
https://www.sip-scootershop.com/en/product/racing-exhaust-sip-road-banana_24169000
@valvitola avatar
@valvitola avatar
Found this Carburator Kit
https://www.sip-scootershop.com/en/product/carburettor-kit-sport-shbc-1919_19622800?q=Carburator%20kit%2019
I guess I only need to choose a crankshaft, am I forgetting anything else?
@swiss1939 avatar
@swiss1939 avatar
Bearings, seals since you are in there anyways, plus anything else that's damaged when you open it up.
@valvitola avatar
@valvitola avatar
Hope this is my last question before embarking in this. What about primary drives? 22/63 2.86 or 24/72 (3.00)?
https://www.sip-scootershop.com/en/product/gearbox-22-63-286-teeth_15310000?q=Gearbox%2022/63
[ Time: 0.0121s ][ Queries: 4 (0.0036s) ][ live ][ 313 ][ ThingOne ]
