@stollerscoot avatar
1964 VBB
1964 VBB
Hey all, I've spoken to a bunch of you before. I'm restoring a 64 VBB and am almost at the point of testing the engine. I want to test it in the stand first rather than in the frame. Since the engine hasn't run in years since being rebuilt, everything is dry. Obviously I'd add oil to the case, but about the cylinder, etc. is there a proper procedure I should follow?
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
With it sitting that long, any prelube has probably migrated to the bottom of the case. I would pull the spark plug. Spray some two stroke premix into the carburetor with the throttle slide open to the case. Spin the motor by hand while your spraying to lube up the internals a bit. Spray some premix into the cylinder as well. Kick it over a few times to get the mixture circulated. Put a few drops of two stroke oil in the inlet of the carburetor also. Then put the plug back in and try starting it. There will be a little lube on the bearing and other wear surfaces that way.
1964 VBB
1964 VBB
Thanks Chris,
That's a huge help. I knew there had to be something I should do to 'pre-lube' the cylinder, etc.
Stay tuned for the inaugural start. Scooter emoticon Scooter emoticon
Vespa T5 251, Lambretta GP200
Whenever I start an engine that has been left for a while I remove suppressor cap and do flooding starts. Take plug out to confirm that it is well wet, have a nice cup of tea and then start as normal.
[ Time: 0.0124s ][ Queries: 3 (0.0045s) ][ live ][ 313 ][ ThingOne ]
