@aa-gts avatar
HPE(2) 300 Super Sport
@aa-gts avatar
HI, anyone on here fitted both the SIP digital speedometer and a Kubler ABS Tone Wheel to a HPE yet?
I can't seem to get the speed to read correctly - when my sat nav say 30mph my speedometer reads under at 27mph.
I've trust adjusting the wheel circumference setting both higher and lower from the 1480 factory setting but cannot find that sweet spot -anyone else had any luck?
@mike_holland avatar
GTS300 Super 2015 Blue, GTS300 Super 2023 Beige
Sounds about right. The SIP speedometer is more accurate than the Piaggio one, so the speed ring will over-correct and make the readings too low. I would be looking for a way to adjust the reading on the speedo.
An alternative would be to scrap the ring and go for a ForceMaster 3 which will sort out the rev and speed limiter without affecting the speedo reading. But a bit expensive.
[ Time: 0.0080s ][ Queries: 3 (0.0023s) ][ live ][ 313 ][ ThingOne ]
