Vespa s 50cc
Vespa s 50cc
My indicators blink when I put in the keys and twist however as soon as I turn on the engine the indicators stay solid. Anyone got any suggestions?
@jkj-fz6 avatar
@jkj-fz6 avatar
Voltage regulator? Measure the battery voltage with the engine off and with it running.
@baba12 avatar
2018 Vespa 300 GTS Touring
@baba12 avatar
It is also possible that the relay unit or flasher unit as some call it maybe kaput.
I believe the S50 has the flasher unit as part of the regulator. So check as above. If the voltages are OK you can remove the flashing feed from the regulator and substitute a two-prong motorcycle flasher relay. One for a GTS would be fine.
[ Time: 0.0072s ][ Queries: 3 (0.0015s) ][ live ][ 313 ][ ThingOne ]
