Vespa PX 200
Vespa PX 200
Howdy all,
So: When I acquired my scooter, I found a piece of electrical tape on the top of the fuel gauge sender (just forward of the fuel tank cap), and I assumed it was there to keep the electric leads connect to the fuel gauge sender/sensor in place. After a few months of sporadic riding -- during which I the scent fuel -- I noticed that the tape had come loose and that it had been covering a small hole through which I could plainly see into the gas tank. That is, there was, in effect, a hole in the sender/sensor cap and, therefore, a hole in the fuel tank directly under the saddle.
Can I simply tape the hole over again? Is there a reason *not* to cover it over (that is, does it *want* to be open to the air)? Would it be better to buy a replacement piece that had no hole?
Thanks in advance,
Shawn
@safis avatar
@safis avatar
A photo would help. The sender is at the back of the fuel cap and if it's an autolube PX there should also be a small oil cap at the left of the fuel cap...
Vespa PX 200
Vespa PX 200
Here you go! (Note: the hole in question is 'circled' in purple and definitely to the *rear* of the main fuel tank cap; that hole looks directly into the fuel tank.)
@safis avatar
@safis avatar
You're missing one of the contacts. Either change the whole unit or find a plug that fits the hole. Tapes, etc. will always come off cause of the fuel. And unfortunately this sender is the very expensive one, cause it's discontinued. I had the same on my T5, it was broken and leaking. It was cheaper for me to buy the newer version PX tank and sender unit (plastic)...
Vespa PX 200
Vespa PX 200
Thanks kindly. I found this item on EBay:
https://www.ebay.com/itm/Petrol-Tank-Fuel-Level-Sensor-Sender-Vespa-PX-Scooter/283934661928
Is it the answer?
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Is it the answer?
That doesn't look the same, I see screw holes in that one and not yours, yours looks to have three wires and that has two. I think the one you linked to is a newer unit. Looks like what is on my 2007 Stella.
Vespa PX 200
Vespa PX 200
Is it the answer?
Thanks!
[ Time: 0.0101s ][ Queries: 4 (0.0043s) ][ live ][ 313 ][ ThingOne ]
