The first 2 photos show the L cover purchased from Scooter West with an additional power outlet cover purchased at a boating supply store. I removed the electrical connections so I ended up with a finished cover used to route the cable that goes to the helmet. When not in use i just push it back in and close the cover.
The next two photos show the compartment above the glove box where I routed the power/audio cable from my garmin 276C GPS towards the front of the scooter into the back of the GPS. A hole was drilled from there into the glove box to route the autocom cable from the glove compartment thru the blank power outlet going to the helmet. The same hole was used for the sound wire from the GPS to the Autocom. I hard wired the GPS unit to the back of cigarrete lighter.
This photo shows the GPS power/audio wire comming out of the front fairing.
The next two photos show the Autocom Unit and iPod in the glove compartment.
The last photo shows the GPS attached to the right screen arm with a RAM mount.
Pedro
